RCU Forums - View Single Post - Echo BME twin
Old 02-27-2007 | 07:50 PM
  #44
tim220225's Avatar
tim220225
Default RE: Echo BME twin
OK guys here are some pictures of the case and mount all bead blasted. I am also listing the Homelite part numbers for the reed valve assembly that you need. These parts fit many of the Homelite saws. When you call they may ask for a model number, I used SXLAO for the model and UT-10045 for their internal number. The model number stands for Super XL with automatic oiler. Look back at my other post here for a picture of the assembly.
Part numbers are as follows:
59274- Gasket - Spacer
59718-Spacer
63260A- Retainer - Reed valve (the rubber seal that holds the reed petals to the pyramid)
63253- Seat - Reed valve (the pyramid that the reeds attach to)
59722- Gasket - Carburetor
Here are the Homelite obsolete parts dealers who have these parts. PDQ and Eversharp seem to be the easiest to get on the phone. There are more but you need to call Homelite parts line for more names.
PDQ 800-444-0732
Hawkins Brothers 573-588-4731
Charles Moody 315-845-8664
Eversharp 330-723-2480
The reeds in fiberglass can be bought from Boyesen Engineering 800-441-1177. The part number is OER30401. BME and Brison used the same reeds in their engines. The mount on these cases is designed for these also but of course you can adapt if you have something else. All the parts from Homelite come to about $22.00 or so. The reed petals are $6.00 each and you need four. Hope this helps everyone who has one of these. Took me a long time to find all this out when I did my Echo 61cc twin conversion.
ID:	631148   Click image for larger version
