RE: engine/prop for P51 PTS help
Go with a 4 stroke. Sounds better. Is a lot more forgiving in that the larger prop will make landings easier and takeoffs less torquey . A Saito 72 or 82 should fly it nicely. If the plane weighs closer to 10LBs then I'd go with the Saito100.
