I just purchased a Smartech Tiger II. Believe it or not I went into this knowing that I would have to upgrade the servos and that if improperly tuned dealing with burned out clutches. Within the first 3 hours I burned the clutch completely which locked the drive train up. As I expected to do as I learned and worked out any bugs in the car and my knowledge. Now the thing runs like a scalded ape. Parts are cheap and easy to get. A new clutch cost $2.00. I save at least $200.00 by buying this car instead of dealing with local dealers. The best website I have found for parts is "www.raidentech.com" in California. I have also found that if you take it to your local hobby shop they will be able to cross reference some part just by measuring them against other brands
Later USMC Retired and living on a budget
