RE: Echo BME twin
Do you mean running the bolts from the mounting plate in? The plate mounts with four bolts in the rear of the case half. No way to run them through. The cases are held together by two bolts each in front and back at opposing corners of the case. I looked at the case again, I may be able to shave just enough off to eliminate the logo. However at that point the washer behind the case bolts would stand above the case a bit it appears. Not a big deal but maybe not worth the effort. We will see.
