RE: Moki 2.1 Engine
If you prime the engine wet then give a slight flick back against compression the Moki will start easily. The Dave Patrick Moki will handle 10%. Older versions would use 0-5% fuel. I try to use one fuel for all which is 10% so I sold my Moki even though it’s a great motor. Use large fuel tubing or med with the Cline. The Cline works great also. If you have tank placement issues then go with the Cline. Follow the long break in procedure exactly and you will have a fine engine, one of the best!
Carl
