RCU Forums - View Single Post - Official HPI MT2 Thread
Old 02-28-2007 | 01:10 PM
  #13486
arapoda
Default RE: Official HPI MT2 Thread
Let me just check I'm getting this right, as this is an expensive mistake if not done correctly...
I need to take the black case off, remove the e-clip, take the bearing off etc, and place the shim so that it is sitting on the gear, then put the bearing back on, and everything else, then the black case, and that's it? How many should I use, as there's three shims in one pack.
I think I've gone cross-eyed! What I just said makes no sense as that would move the gear away from the pinion gear, no?
