RCU Forums - View Single Post - How do you make good wing saddles?
Old 02-28-2007 | 02:58 PM
skeeter_ca's Avatar
skeeter_ca
Default RE: How do you make good wing saddles?
The silicone method sounds the easiest. I was thinking about using some micro balloons mixed with epoxy, squeeze it between the gaps then let it dry and grind off the excess and that would give me a hard surface that wouldn't flex or come off. Anyone use that method.
