scale fuselage engine questions?
i'm putting a long ranger fuse on my GPH. two questions...how large of a cooling hole do i need in the bottom for the engine. just the size of the cooling shroud exit, or as large as the entire bottom surface area of the engine? also, how long of a exhaust extension/deflector can i put on the muffler without causing back pressure problems? is about 4-5 inches too long?
thanks,
gregg
