RCU Forums - View Single Post - wont start?
Thread: wont start?
Old 02-13-2003 | 07:34 PM
i8tweety's Avatar
i8tweety
Default wont start?
Try this
remove the air filter
back off the idle adjustment screw
close the carburetor
slowly turn in the idle adjustment screw until the carburetor starts to open
when it's open about 1 mm, stop
If it tightens against the barrel and the barrel doesn't rotate open at all, try moving the barrel (wiggle it in and out a little so the idle adjustment screw locates the groove the the carb barrel
Good luck
