RCU Forums - View Single Post - wont start?
Thread: wont start?
Old 02-13-2003 | 07:49 PM
buyrbware
Default wont start?
The screw at the top is called the barrel stop screw (a scre and a spring) dont tighten it down to tight it will lock your barrel. The correct procedure is to tightne it down so you get full throttle stop and positive w.o.t. then set the idle adust on the side. If the barrel screw is out of adjustment so will be your idle screw
