wont start?
ok mandont turnit all the way in.that will make it toooo fast and flud the carb were it will not start.back it out almost all the way then turn the car on and start the car. and move the trim of the idle were the car will still run.then the idle screw in tell the car will run good.then move the trim back were the car wil still run you may need to move the armon your servo so yur brake will not stop the motr.that should work man let me know iwill be here ok.tylern
