RE: Electrically Confused
One small piece of additional information.
No matter which charger you use, fully charging any size lipo will take between 1 and 1.5 hours. This assumes: 1) the battery is fully discharged; 2) you charge it at the recommended 1C charge rate.
If you charge at a rate below 1C (often recommended to maximize battery life), the charge time will be longer.
- Jeff
