T, use an HPI easy start. It bolts right on and the shaft goes through the back so it will work on your buggy. It costs about $50.00. I have several back plates and one easy start. Make sure you get the easy start with the correct size backplate as they make two different sizes. Hope this helps you.
Keith
ORIGINAL: trinogt
I have had very good luck with my electronics for over a year now, with almost a gallon of fuel used up. After a hiatus from missing parts that I now have, I got to driving my buggy again. I found the throttle servo no longer works! I bought a Traxxas servo new for $5 on ebay. Works great. (I am running 2wd too, after being gipped out of the universal joint shafts (#40177))
I also found that I no longer have first gear in my tranny! It stays in second, so is gutless off the line. Anyone know how to cure this? I don't see any instructions on how to adjust the trans, or even what tool is used to do it.
I also pulled the start cord to the end, so now I have to rermove the engine and inspect the recoil. I would like to find a way to install a hex starting recess and get rid of the pull start.
