RE: Echo BME twin
I wanted to use the key way so I tapped the crank 1/4x28. It just started to break trough the bottom of the key way. I figured I could make a stepped stud if I also use it to retain the prop. 1/4 inch in the crank and 10mm for the prop. I like single bolt prop studs so I don't have to mess around drilling the hubs for a multi bolt set up.
