RE: Echo BME twin
Tim
Thanks again for the short blocks. I will get some pictures before I have it welded.
I got a response from keith on the welding. He suggested using stainless filler rod to join the cranks. On welding the pins he suggested to me not to weld them, but to drill them with a carbide bit and pin them. He said the heat from welding loosens the press fit to the point that it can be a problem.
