RCU Forums - View Single Post - Speed control???
Old 03-01-2007 | 03:27 PM
HeliTB's Avatar
HeliTB
Default RE: Speed control???
What is your throttle curve set at? If you are running a throttle curve at anything less than 80% for extended period of time the ESC will heat up. Most ESCs and motors run more efficient and cooler when the throttle of the ESC is run at 80% or higher.
