A simple problem
Out of the 7 screws holding the HL deck to the hull, thanks to an ham fisted assembly worker and far too short screws, only 2 actually grip.
Just wanted to know what is your remedy?
Before now i have split a match down its length and glued it in the stripped hole so giving the screw something to grip on.
But i've got a feeling these screws will need to be removed very often so was thinking of gluing in threaded inserts and using machine screws, unless you have a easier remedy..........
