RCU Forums - View Single Post - PIN-STRIPING .....whats best.....
Old 03-01-2007 | 04:51 PM
MadScientist
Default RE: PIN-STRIPING .....whats best.....
I just did this very thing last night with monocote. The trick is to get it tacked down at one end and while pulling slightly, use your trim iron to seal it down. As you go, the heat from the iron makes the stripe stretch a bit, and that's where you can use the elasticity of monocote to make smooth tight corners. it takea about 10 minutes or so of practice, but once you get it, it's no big deal.
