RCU Forums - View Single Post - Mig 27 Foam Drone,, Carl Goldberg
Old 03-01-2007 | 05:12 PM
BIGMIG
Default RE: Mig 27 Foam Drone,, Carl Goldberg
I will try and put some pictures on here latter on tonight if I can figure out how to do it.I'm not a computer wizzzzz--------As you know there is a plywood tray inside where the motor mount rails are and also a plywood strip under that on the bottom.I just drilled a 3/16 hole to match the diameter of the front strut and there is a collar on the bottom and top to hold it in place.I had to cut out some of the foam on the bottom of the cock-pit piece for the stearing arm clearance.I'll take a few pictures latter and see if I can get them posted on here-----------
