RCU Forums - View Single Post - Aircraft overpowering?
Old 03-02-2007 | 07:00 AM
randy racer
Default RE: Aircraft overpowering?
i allways use the biggest moter i can ballance on the plane without adding tail weight and also not over load the wing. wing loading is overlooked by many but a heavy plane won't fly as well as a light one. in most cases on a 60 size plane i will use a 91 2 stroke. i will also reinforce the fire wall with some tristock and pin it with some dowl rod.
randy racer
