RE: TNX 5.2
Wont do the same job as the plastic composite one. The revo pipe is 1/10 scale designed for small block engines. TNX 5.2r uses a big block engine and if you use 1/10 scale pipe you wil restrict the engine.
If you really want to change the pipe, go for sometthing like OFNA JP-2 or JP-3.
