RE: Walkera Dragonfly #36
thanks for the advice, i dont knwo if its a problem but the tail blade a doesnt seem to spin fast enof, it seems to slip alot possibly? also when i get it going at about half speed i can see the center lock that locks the position of the tail blades start spining out of center, starts making small circles, could this be a very small bend in the shaft as thats the sort of thing i would expect, or something is not centerd perfectly, could also be causing the slow down of the blades aswel but i have to get it up to at least half speed to notice it, this then could also explain why its hevily turning anti-clockwise.
i tried getting another video but its night time and the lighting inst very good and the battery just went out on me aswel.
the only other things i could think of it being was the band was a little to tight or too loose or the tail blade isnt balanced and is making the thing shake alot, or a combonation of all of them?
so far i have centerd the tail blades, centerd the tail servo, turned the gyro to normal, it just seems to be the tail blade asembily, the actual part the servo controls, just before it splits either side of the axle to the tail blade is steady while the tail blades start wobling, im just out of clues on what to do.
