RCU Forums - View Single Post - axe cp thread
Old 03-02-2007 | 10:39 PM
  #240
markind's Avatar
markind
Default RE: axe cp thread
ORIGINAL: nzak
Mark!! (ind)
You had the 2200mAh battery just straped under the heli, or were you using it to power the heli? I want to use a battery about that size. If you had your regular 1320 powering the heli and the 2200 just as dead weight, I will be VERY impressed!
Thanks, Nick
No, I had the 2200 powering the heli. The normal battery tray was empty, and the pack's wire prevents the canopy from going on.
So, no canopy plus the aircraft is sluggish and obviously overloaded. The increase in juice does not quite make up for it.
Certainly, you would get more bang for the buck and weight with those economy 1500's. Meanwhile, I'll make another run with just 3 of the TP 1320's and see how it goes
