RCU Forums - View Single Post - Purchasing Mutliplex Minmag
Old 03-02-2007 | 10:52 PM
aeajr's Avatar
aeajr
Default RE: Purchasing Mutliplex Minmag
Minimag
http://www.multiplexusa.com/models/P...rs/minimag.htm
Thsi one is receiver ready. Put in your receiver and fly!
http://www2.towerhobbies.com/cgi-bin...?&I=LXNXV1&P=7
The all up weight of the palne, based on stock power system is 20 ounces or 1.25 pounds.
I would sugget you shoot for 75 to 100 watts per pound for spirited flying. That means you want a motor in the 90 to 125 watt range.
One of these should work nicely if the plane has a stick mount for the motor
http://www.maxxprod.com/mpi/pdf/combo-049-070.pdf
Or this might be better if you can't use a stick mount
http://www2.towerhobbies.com/cgi-bin...&I=LXLWT6&P=ML
