RE: Heng Long Airsoft Upgrades
The motor and gears are interchangeable. It's one side of the VS case that's wider, you can simply swap all the guts from the VS into your HL. If you want more power, lengthen the barrel, use an airsoft barrel cut to 207mm or so if you want an accurate length.
