RE: Help aligning semisymetrical wing and stab
That would give you a 0-0 wing to stab difference. Maybe not a good thing. It would trim in the end but it would do so with some up elevator trim. And many consider permanent trim on a surface to be unsightly. You'd be better off to set the stabilizer about 1.5 to 2 degrees negative to the airfoil centerline that you described. Which, incedentally is how we all describe the airfoil center line and if very proper.
If it'a a sport model then 1.5 to 2'ish would be enough since you'll likely put the CG back far enough to make it balance out the trim. If it's more of a trainer with a higher degree of pitch stability then 2.5 to 3 difference would be a good starting point.
The closer to 0-0 you set all this the less downthrust you'll need. As it gets more into the trainer realm you'll find you need more downthrust to avoid a strong nose up reaction to changes in speed related to throttle use. With a 3 degree incidence angle difference in the wing and stab it would not be unusual to use 4 or 5 degree of downthrust angle in relation to that wing center line.
