RCU Forums - View Single Post - Pushrod set-up for Fun-Fly plane???
Old 03-04-2007 | 11:12 AM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Pushrod set-up for Fun-Fly plane???
The Sullivan I use has a solid steel rod all the way through it. Some of the Sullivans use a plastic rod inside a plastic tube. These only have steel threads at the end. Unless you need to make a sharp turn get the all steel. The plastic on plastic needs to be supported more often and your trim will change with the weather. I can't tell you which color is which.
David
