RCU Forums - View Single Post - Ts Oxalys build
Old 03-04-2007 | 02:44 PM
Rune
Default RE: Ts Oxalys build
the tail is alsomt finished just need the skrews that lock the stabs .
servoes for rudder and elevator is in place the wires for controlling the tail is also finished!
i will use metal wire as i have used before , had no problems with that .
The spot to drill the holes for the controll horns on the rudder was not right, silly but i had a decal that had to cover it , the maual told to place it 10 mm wrong.
ID:	634792   Click image for larger version
ID:	634793   Click image for larger version
