RCU Forums - View Single Post - Which Cell Balancer
Old 03-04-2007 | 02:48 PM
mykul812's Avatar
mykul812
Default RE: Which Cell Balancer
I have the same charger and I use a common sense rc (name of the company /supplier), ultra balancer PART# UB-26.
The one thing I will note is that the molex pin connector onj the balancer does not have a fail safe for plugging in your battery. In other words, you will fry this thing if you do not make sure that the black ground wire is in pin #1. I had a battery that came with the wires backwards and because I assumed that the orientation was correct without checking. The little sucker fried in about 1/2 second!!![&o]
Michael
ORIGINAL: inlinezenoah
This is the charger i have. I have never charged lipo's before, Can someone suggest a fairly cheap cell balancer that would go good with this charger. Thanks
Multiplex multlcharger ln-5014 >[img][/img]
