RE: Gain
Hello, try start with the basic baseline, center the tx trims and adjust the proportion till the copter stops turning in the wrong direction and begins to turn the opposite. now you have an idea where the proportion midpoint is, adjust the rest with the tx trims. try doing the gain then after you have it not spinning. you may have to tweak it a bit more again to perfect it.
