RE: To thin or not to thin.
Yeah, That's kinda what I'm going through right now. I'm doing more flying than the plane. I'm experienting with different ways of applying the covering and have come up with a good method. Use the stick glue after a couple of coats of dope and sanding, then use the 50/50 dope thinner works pretty good. You still have to do something about the fumes but it's alot less of a problem with gettin th tissue paper to do what you want,in otherwords it stays down and where you want it and I don't think the dope has any adverse affects on the glue, it seems to be working out alright so far. I have the bottom of the plane left to cover and then one more coat at least of dope and then I'll think about painting it.
