RCU Forums - View Single Post - Anyone have a good way to convert degree's into inches for throws?
Old 02-12-2003 | 03:05 PM
Gordon Mc
Default Re: Anyone have a good way to convert degree's into inches for throws?
Originally posted by JohnVH
Would appreciate any info on how to do it, or how to make something to do it or????
It's called trigonometry - ya know - all that SOH CAH TOA CAO SHA CHO stuff from high school ?? (I'm assuming that they teach that in the US - I learned it in RSA).
In this case , the distance that you are looking for is opposite the deflection angle, so you want to find O ; use the hypotenuse (H) as your other distance.
So, you're working with theta (the angle), O (the distance that the control surface tip is from its neutral position, and H (the distance from the hinge centreline to the tip of the control surface, as measured in cross section).
Sin (Theta) = O / H
=> O = H * Sin (Theta)
Grab your pocket calculator and use the above - out pops the answer.
Gordon
