RE: Engine Stands?
The Test Stand on post #20 is a new cabinet grade plywood CNC router cut kit available from RC Showcase. It may be finished as you wish, is of interlocking construction that only requires to be screwed and glued. We do not yet have it posted on our website, but stay tuned.
We also have as an accessory the very beefy, 3/4" CNC machined 6061 aluminum multi ajustable engine mount. For those serious about bench running engines of course!!
This test stand is strong enough to run the ZDZ 420 opposed 4 cylinder or RCS 400 radial engines and will accomodate setups with canisters or tuned pipes easily.
Test Stand- $175.00
Aluminum multi adjustable mount- $225.00
Give us a call if intetested in a test stand that is admittedly over engineered for that extra margin of safety.
