RCU Forums - View Single Post - Help with Genesis shifting (into neutral?)
Old 03-05-2007 | 01:17 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: Help with Genesis shifting (into neutral?)
You do have just one pinion at each shift. The small pinion is your first gear, the larger pinion is your second gear and third gear is inside the tranny. It sounds the one way bearing(Drawn Cup Roller Clutch) inside the tranny may have malfunctioned or is malfunctioning..
