RE: Echo BME twin
Very nice. Looks like you got the reed assembly too. I see what was mentioned about the crank not sticking out real far once the bearing is on. Do you need to slide it back yet? Either way I think you will have enough of the hub riding on the taper so it won't be an issue. I have done some short like that too. Do you still plan to pin the journal too? The 201 carb will be perfect for the engine. I use that same carb on the 44 and 50cc Echo singles I do. Actually it is the same carb BME uses on his 44 and 50cc singles too.
