RCU Forums - View Single Post - Lh110 Convert To Electric - Please Help!
Old 02-12-2003 | 03:00 PM
fig8
Default Lh110 Convert To Electric - Please Help!
I was having a tail glitch problem and mad swinging..
My setup was the recommended stock way gyro stuck to the side under the rx. basically I got tired of the tail causing so many problems.. so I read through about 500 posts regarding this exact same subject
I tried everything BUT making a small plywood platform to sit above the tailboom behind the crutch.
So I broke down and repulmbed the wiring no wires are close to each other except for the servo wires... And I made a little tray that sits over the tail boom on top of the crutch.. well after a month of these tail glitches.. that solved my problem!!
hope this helps
Gregg
