Perry Pump Regulating Smoke System
Can you run this pump off the exaust pressure?
Would it be possible to tap into the YS Regulators return line that goes back into the tank?
Does the oil tank need to be vented, would it leak? or can I use a one way check valve here?
Also any other info regarding the smoke system would be apriciated.
Regards
SuperH
