Please help!
Reset your needle valves.
Main needle 1 1/2 turns open from close
Idle needle (inside throttle arm) 2 1/2 open from throttle closed
To get the fuel started, try putting your finger over the muffler exhaust hole to pressurize the tank. Obviously, do not do this if the muffler is hot!
Once fuel is in the motor, as long as you have a good glo, it should start.
Let us know if you have any more trouble.
Jeff G
MRC
