Change out the landing gear......
with TNT replacement gear. You also need to look at the landing gear mounting plate. Very weak. The tank is causing a lot of problems at our field, so most don't use it. They are also glueing in the stabs on instead of the sloppy removable system (this may be a first run issue.....)
Great flying bird......
Pug
