Are you saying that as speed increases, load on the engine increases as well? I would have thought that as speed increased, engine load would decrease proportionate to the amount of pitch in the prop and the speed with which it moved.
ORIGINAL: pe reivers
The graphs show however clearly, that the higher pitched prop will ask more engine power at higher speeds, even though the heavily graded prop diameter is less.
