RE: Echo BME twin
Here is a pic of the crankshaft fixture we used. Its milled from a single piece of aluminum. You may have to do a little math to get it right but it supports the crankshaft and the two thin pieces in the middle support the crank pins. When all is touching supports the crank pins are 180 degrees apart.
