RCU Forums - View Single Post - RealFlight 3.5 problem
Old 03-07-2007 | 03:37 PM
inky00
Default RE: RealFlight 3.5 problem
ORIGINAL: IMAC781
Hey guys,
After I upgraded V3 to V3.5 with an upgrade disc my MX400 heli won't take off. The Aircraft Editor shows three cells in series but a total voltage of only 4.2 volts. One cell. The total voltage amount is in a grey area and doesn't change when I put the cursor on it. How can I change the grey areas so they can be edited. Also when launching the MX400 I get an error nessage "lipoly 1500mAh battery not found, default will be substituted". Does GP have a stash of battery downloads somewhere I don't know about?
Chris Hogan
Miami, FL
I am not sure what is happening with the voltage readings but have you checked that a lipo is being used and not Nicads,i would imagine because you didn't have the 1500Mah lipo it has given you a nicad as a default.Have you tried the swap pages at WWW.knifeedge.com/forums for downloads,there are tons available.
