RCU Forums - View Single Post - Parachute recovery system - does it exist?
Old 03-07-2007 | 05:53 PM
MadDriver's Avatar
MadDriver
Default RE: Parachute recovery system - does it exist?
ORIGINAL: rlipsett
the thing with a parachute rescue system is if you had time enough to use the system you have more then enough time to correct the airplane unless you have a catastrophic aircraft failure
And I think it's safe to say that most crashes happen due to pilot error, and not a malfunctioning airplane... at least from what I've seen.
