RE: Official Hyper 8 Thread
adz06, it sounds like you need to adjust the idle stop screw on the carb so it will not close more than 1 mm. For a throttle return spring look in the Sportsworks section of the hobby shop and you will find a pack of two springs - cheap. Another solution is to use a small rubber band around the ball on the slide and the air inlet.
Ed M.
