Hey what about this
http://tkocompetitiondev.com/shop/pr...roducts_id=292
Vibra-Tite is a special aerobic threadlocker. It is NOT like Loctite that cures without air.
You apply to your clutch bell screws or wheel nuts or other hardware...filling at least half the height of the threads and let dry..7 to 10 minutes. Once cured it forms into a plastic like substance that stays on and allows you to remove and reinstall the hardware many times without re-application.
You can pre-treat your hardware and put it in your box for later use. It also works well for screwing into plastic parts!
