It's actually a Fusion 90 size with mighty 110. Weight is 7lbs 8.5 ozs. I'm using a 16x6 APC prop. I've got exactly one flight on it. On the first landing the tailwheel broke off.
Right now it flys very nice but is a little hard to land. I may be just a tad back too far on the CG. It's a pretty impressive airplane but a little hard to build and expensive. I bought the all white version and put the trim scheme on myself.
It does excellent harriers and pretty good KE. Everything else is about the same as the UCD60. You may ask how I know so much about the plane with only one flight?.....This is my second one. They will crash if left unattended.
I think the quality of the kit is a little less than average. I had to cut the side open on both planes to route the servo wires. Also the covering isn't as good as monokote. The hardware is pretty good. I used it all but there is better stuff out there.
I've replaced the tailwheel with the Sig Mayhem type and hope to fly again this year...depending on weather.
I do like the way it flys and I'm hoping it will be a little stronger than the UCD.
Anyways...
Barry
