RCU Forums - View Single Post - converting a .45 OPS engine?
Old 03-08-2007 | 02:18 PM
hondacb73
Default RE: converting a .45 OPS engine?
Thanks for the quick reply!!! I'm not exactly sure what you meant with front and rear,so I'll try to explain....the crankshaft with flywheel are on the same side as the exhaust.The intake/carb are on the opposite side of the exhaust.So I guess that means it's a rear intake as I would call the crankshaft-side the front....right?
ID:	637887   Click image for larger version
