RE: converting a .45 OPS engine?
Hopefully someone that's real familiar with the OPS engine will check in. I believe it is as simple as rotating the back plate to a new position to get the reverse rotation but you will have to be carefull that you don't create an interference for the liner or piston when the back plate is rotated. You do have what we term a rear rotor engine.
