RE: Can I use this grease in the diffs?
If you're a beginner you won't notice the difference between the weights of diff oil except maybe the real thick lockup oils. That grease will work fine for your diffs. If you start racing you can start experimenting with different weight diff oils to tune for traction. Trying to tune traction with diff oil for your basher is a waste of money imo.
Matt
