RCU Forums - View Single Post - Nitro Guide and FAQs
Old 03-08-2007 | 10:44 PM
hpi apollo's Avatar
hpi apollo
Default RE: Nitro Guide and FAQs
you DO NOT use your hsn for a temp adjuster, when you are in cold weather you need to run richer because cold air is more dense, and more air per voulme of fuel makes it run lean, you need to run richer, but you also might have to cover up some windows to keep the temp up, or if that doesnt work, you need to wrap a paper towell around the head or maybe some foil
